Beam Design - Reichl 3.5x15 glulam
Size: 3.5 x 15
Design Span (L): 15.58 ft.
Clear Span: 15.17 ft.
Total Span: 16.00 ft.
Bearing (lb): 5 in.
Live Load: 680 plf
Dead Load: 170 plf
Selfweight: 191.8 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 196.9 lbs
Beam Design 2023A73
3/11/2023 1
d = 15.000 in.
Beam Design 2023A73
3/11/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (187.00 + 5)] x (12 in./ft.)3 = 5.83 ft3
Volumespan = N[A x L] = 1 x [52.50 x 187.00] x (12 in./ft.)3 = 5.68 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.83 = 196.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.68 = 191.8 lbs
680 plf
170 plf
  ws = 12.31 plf
15.58 ft.
15.17 ft.
6898.33 lbs
6898.33 lbs
Beam Design 2023A73
3/11/2023 3
fb = = 2393.1 psi
 fb = 2393.1 psi < Fbx' = 2760.0 psi  (CSI = 0.87)   ➜  OK
Beam Design 2023A73
3/11/2023 4
fv* = = 161.17 psi
 fv* = 161.17 psi < Fvx' = 304.75 psi  (CSI = 0.53)   ➜  OK
fv = = 191.96 psi
 fv = 191.96 psi < Fvx' = 304.75 psi  (CSI = 0.63)   ➜  OK
Beam Design 2023A73
3/11/2023 5
ΔLL = = 0.51 in.
(L/d)LL = 187.00 / 0.51 = 367
 ΔLL = 0.51 in = L/367 < L/180   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 187.00 / 0.65 = 290
 ΔTL = 0.65 in = L/290 < L/120   ➜  OK
Ab = b x lb = 3.5 x 5 = 17.50 in2
fc⊥ = = 394.2 psi
 fc⊥ = 394.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.61)   ➜  OK
Beam Design 2023A73
3/11/2023 6
