Size: 12.25 x 37.5
Design Span (L): 49.00 ft.
Clear Span: 48.00 ft.
Total Span: 50.00 ft.
Bearing (lb): 12 in.
Live Load: 1125 plf
Selfweight: 5277.4 lbs
Dist. Selfweight: 107.70 plf
Total Weight: 5385.1 lbs
CV Volume Factor 0.751b - - - - -
Beam Design 2023A72
3/10/2023 1
b = 12.250 in.
d = 37.500 in.
A = 12.250 x 37.500 = 459.38 in.2
Sx = (12.250)(37.500)2/6 = 2871.09 in.3
Sy = (12.250)2(37.500)/6 = 937.89 in.3
Ix = (12.250)(37.500)3/12 = 53833.01 in.4
Iy = (12.250)3(37.500)/12 = 5744.58 in.4
Beam Design 2023A72
3/10/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [459.38 x (588.00 + 12)] x (12 in./ft.)3 = 159.51 ft3
Volumespan = N[A x L] = 1 x [459.38 x 588.00] x (12 in./ft.)3 = 156.32 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 159.51 = 5385.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 156.32 = 5277.4 lbs
Distributed Self Weight (ws) = = 107.70 plf
1125 plf
  ws = 107.70 plf
49.00 ft.
48.00 ft.
50.00 ft.
32692.54 lbs
32692.54 lbs
Beam Design 2023A72
3/10/2023 3
CV = = 0.751
CV = 0.751 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.751) = 2073.9 psi
fb = = 1640.4 psi
 fb = 1640.4 psi < Fbx' = 2073.9 psi  (CSI = 0.79)   ➜  OK
Beam Design 2023A72
3/10/2023 4
fv* = = 91.27 psi
 fv* = 91.27 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
fv = = 104.62 psi
 fv = 104.62 psi < Fvx' = 304.75 psi  (CSI = 0.34)   ➜  OK
Beam Design 2023A72
3/10/2023 5
ΔLL = = 1.51 in.
(L/d)LL = 588.00 / 1.51 = 390
 ΔLL = 1.51 in = L/390 < L/360   ➜  OK
ΔTL = = 1.75 in.
(L/d)TL = 588.00 / 1.75 = 336
 ΔTL = 1.75 in = L/336 < L/240   ➜  OK
fc⊥ = = 222.4 psi
 fc⊥ = 222.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.34)   ➜  OK
Beam Design 2023A72
3/10/2023 6
