Size: 4 x 8
Design Span (L): 11.71 ft.
Clear Span: 11.42 ft.
Bearing (lb): 3.5 in.
Selfweight: 141.1 lbs
Dist. Selfweight: 12.05 plf
Total Weight: 144.6 lbs
Beam Design 2023A71
3/9/2023 1
Beam Design 2023A71
3/9/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [25.38 x (140.50 + 3.5)] x (12 in./ft.)3 = 4.23 ft3
Volumespan = N[A x L] = 2 x [25.38 x 140.50] x (12 in./ft.)3 = 4.13 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.23 = 144.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.13 = 141.1 lbs
Distributed Self Weight (ws) = = 12.05 plf
ws = 12.05 plf
11.71 ft.
11.42 ft.
1122.30 lbs
1122.30 lbs
Beam Design 2023A71
3/9/2023 3
fb = = 627.2 psi
 fb = 627.2 psi < Fbx' = 1345.5 psi  (CSI = 0.47)   ➜  OK
Beam Design 2023A71
3/9/2023 4
fv* = = 29.02 psi
 fv* = 29.02 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
fv = = 32.37 psi
 fv = 32.37 psi < Fvx' = 207.00 psi  (CSI = 0.16)   ➜  OK
Beam Design 2023A71
3/9/2023 5
ΔLL = = 0.12 in.
(L/d)LL = 140.50 / 0.12 = 1182
 ΔLL = 0.12 in = L/1182 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 140.50 / 0.22 = 632
 ΔTL = 0.22 in = L/632 < L/240   ➜  OK
fc⊥ = = 45.8 psi
 fc⊥ = 45.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2023A71
3/9/2023 6
