Beam Design - Reichl 5.5x13.5 Glulam
Size: 5.5 x 13.5
Design Span (L): 15.50 ft.
Clear Span: 15.00 ft.
Total Span: 16.00 ft.
Live Load: 680 plf
Dead Load: 170 plf
Selfweight: 269.8 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 278.5 lbs
Beam Design 2023A69
3/6/2023 1
d = 13.500 in.
Beam Design 2023A69
3/6/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (186.00 + 6)] x (12 in./ft.)3 = 8.25 ft3
Volumespan = N[A x L] = 1 x [74.25 x 186.00] x (12 in./ft.)3 = 7.99 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.25 = 278.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.99 = 269.8 lbs
680 plf
170 plf
  ws = 17.41 plf
15.50 ft.
15.00 ft.
6939.26 lbs
6939.26 lbs
Beam Design 2023A69
3/6/2023 3
fb = = 1871.1 psi
 fb = 1871.1 psi < Fbx' = 2760.0 psi  (CSI = 0.68)   ➜  OK
Beam Design 2023A69
3/6/2023 4
fv* = = 116.09 psi
 fv* = 116.09 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
fv = = 135.81 psi
 fv = 135.81 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
Beam Design 2023A69
3/6/2023 5
ΔLL = = 0.44 in.
(L/d)LL = 186.00 / 0.44 = 428
 ΔLL = 0.44 in = L/428 < L/360   ➜  OK
ΔTL = = 0.55 in.
(L/d)TL = 186.00 / 0.55 = 335
 ΔTL = 0.55 in = L/335 < L/240   ➜  OK
fc⊥ = = 210.3 psi
 fc⊥ = 210.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.32)   ➜  OK
Beam Design 2023A69
3/6/2023 6
