Beam Design - Reichl Beam
Size: 3.5 x 12
Design Span (L): 15.50 ft.
Clear Span: 15.00 ft.
Total Span: 16.00 ft.
Live Load: 750 plf
Dead Load: 150 plf
Selfweight: 152.6 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 157.6 lbs
Beam Design 2023A68
3/6/2023 1
Beam Design 2023A68
3/6/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (186.00 + 6)] x (12 in./ft.)3 = 4.67 ft3
Volumespan = N[A x L] = 1 x [42.00 x 186.00] x (12 in./ft.)3 = 4.52 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.67 = 157.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.52 = 152.6 lbs
750 plf
150 plf
  ws = 9.85 plf
15.50 ft.
15.00 ft.
7278.78 lbs
7278.78 lbs
Beam Design 2023A68
3/6/2023 3
fb = = 3903.4 psi
 fb = 3903.4 psi > Fbx' = 2760.0 psi  (CSI = 1.41)   ➜  NG
Beam Design 2023A68
3/6/2023 4
fv* = = 219.34 psi
 fv* = 219.34 psi < Fvx' = 304.75 psi  (CSI = 0.72)   ➜  OK
fv = = 251.83 psi
 fv = 251.83 psi < Fvx' = 304.75 psi  (CSI = 0.83)   ➜  OK
Beam Design 2023A68
3/6/2023 5
ΔLL = = 1.07 in.
(L/d)LL = 186.00 / 1.07 = 173
 ΔLL = 1.07 in = L/173 > L/180   ➜  NG
ΔTL = = 1.30 in.
(L/d)TL = 186.00 / 1.30 = 143
 ΔTL = 1.30 in = L/143 < L/120   ➜  OK
fc⊥ = = 346.6 psi
 fc⊥ = 346.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.53)   ➜  OK
Beam Design 2023A68
3/6/2023 6
