Beam Design - Wall 3.5 x9 GLULAM
Size: 3.5 x 9
Design Span (L): 15.58 ft.
Clear Span: 15.33 ft.
Total Span: 15.83 ft.
Selfweight: 115.1 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 116.9 lbs
Beam Design KERRY BOYLE 1330 Hertz Drive Southeast 1
3/2/2023 1
d = 9.000 in.
3/2/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (186.96 + 3)] x (12 in./ft.)3 = 3.46 ft3
Volumespan = N[A x L] = 1 x [31.50 x 186.96] x (12 in./ft.)3 = 3.41 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.46 = 116.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.41 = 115.1 lbs
  ws = 7.39 plf
15.58 ft.
15.33 ft.
15.83 ft.
1443.58 lbs
1443.58 lbs
3/2/2023 3
fb = = 1405.4 psi
 fb = 1405.4 psi < Fbx' = 2760.0 psi  (CSI = 0.51)   ➜  OK
3/2/2023 4
fv* = = 61.14 psi
 fv* = 61.14 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
fv = = 67.66 psi
 fv = 67.66 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
3/2/2023 5
ΔLL = = 0.35 in.
(L/d)LL = 186.96 / 0.35 = 540
 ΔLL = 0.35 in = L/540 < L/180   ➜  OK
ΔTL = = 0.63 in.
(L/d)TL = 186.96 / 0.63 = 296
 ΔTL = 0.63 in = L/296 < L/120   ➜  OK
fc⊥ = = 137.5 psi
 fc⊥ = 137.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.21)   ➜  OK
3/2/2023 6
