Design Span (L): 16.63 ft.
Clear Span: 16.25 ft.
Total Span: 17.00 ft.
Bearing (lb): 4.5 in.
Live Load: 40 plf
Dead Load: 13.3 plf
Selfweight: 93.7 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 95.9 lbs
Beam Design 2023A6
1/16/2023 1
Beam Design 2023A6
1/16/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (199.50 + 4.5)] x (12 in./ft.)3 = 2.57 ft3
Volumespan = N[A x L] = 2 x [10.88 x 199.50] x (12 in./ft.)3 = 2.51 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.57 = 95.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.51 = 93.7 lbs
40 plf
13.3 plf
ws = 5.64 plf
16.63 ft.
16.25 ft.
17.00 ft.
500.98 lbs
500.98 lbs
Beam Design 2023A6
1/16/2023 3
Fbx' = (925)(1.00)(1)(1)(1)(1)(1)(1.15) = 1063.8 psi
fb = = 929.8 psi
 fb = 929.8 psi < Fbx' = 1063.8 psi  (CSI = 0.87)   ➜  OK
Beam Design 2023A6
1/16/2023 4
fv* = = 31.33 psi
 fv* = 31.33 psi < Fvx' = 175.00 psi  (CSI = 0.18)   ➜  OK
fv = = 33.79 psi
 fv = 33.79 psi < Fvx' = 175.00 psi  (CSI = 0.19)   ➜  OK
Beam Design 2023A6
1/16/2023 5
ΔLL = = 0.52 in.
(L/d)LL = 199.50 / 0.52 = 387
 ΔLL = 0.52 in = L/387 < L/360   ➜  OK
ΔTL = = 0.76 in.
(L/d)TL = 199.50 / 0.76 = 263
 ΔTL = 0.76 in = L/263 < L/240   ➜  OK
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 37.1 psi
 fc⊥ = 37.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2023A6
1/16/2023 6
