Grade: SP No.1
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Quantity (N): 4
Live Load: 424 plf
Dead Load: 118.4 plf
Selfweight: 214.4 lbs
Dist. Selfweight: 17.50 plf
Total Weight: 218.7 lbs
Beam Design Pelt 2023A59
2/28/2023 1
2/28/2023 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (147.00 + 3)] x (12 in./ft.)3 = 5.86 ft3
Volumespan = N[A x L] = 4 x [16.88 x 147.00] x (12 in./ft.)3 = 5.74 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 5.86 = 218.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 5.74 = 214.4 lbs
Distributed Self Weight (ws) = = 17.50 plf
424 plf
118.4 plf
ws = 17.50 plf
12.25 ft.
12.50 ft.
3499.37 lbs
3499.37 lbs
2/28/2023 3
fb = = 995.8 psi
 fb = 995.8 psi < Fbx' = 1150.0 psi  (CSI = 0.87)   ➜  OK
2/28/2023 4
fv* = = 64.54 psi
 fv* = 64.54 psi < Fvx' = 201.25 psi  (CSI = 0.32)   ➜  OK
fv = = 76.21 psi
 fv = 76.21 psi < Fvx' = 201.25 psi  (CSI = 0.38)   ➜  OK
2/28/2023 5
ΔLL = = 0.19 in.
(L/d)LL = 147.00 / 0.19 = 779
 ΔLL = 0.19 in = L/779 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 147.00 / 0.25 = 590
 ΔTL = 0.25 in = L/590 < L/240   ➜  OK
fc⊥ = = 194.4 psi
 fc⊥ = 194.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.34)   ➜  OK
2/28/2023 6
