Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 1000 lbs
Dead Load: 75 lbs
Selfweight: 63.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 64.1 lbs
CL Beam Stability Factor 0.442 - - - - -
Beam Design 2023A57
2/27/2023 1
Beam Design 2023A57
2/27/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (189.00 + 3)] x (12 in./ft.)3 = 1.88 ft3
Volumespan = N[A x L] = 1 x [16.88 x 189.00] x (12 in./ft.)3 = 1.85 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.88 = 64.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.85 = 63.1 lbs
1000 lbs
75 lbs
ws = 4.01 plf
15.75 ft.
15.50 ft.
569.57 lbs
569.57 lbs
Beam Design 2023A57
2/27/2023 3
lu = Unbraced Length = 15.750 ft.
lu/d = = 16.80
le = 1.37lu + 3d = 1.37(189.0) + 3(11.25) = 292.68 in. = 24.39 ft.  (NDS Table 3.3.3)
Rb = = 38.25
 Rb = 38.25 < 50   ➜  OK
Beam Design 2023A57
2/27/2023 4
FbE = = 475.60 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1)(1)(1) = 1035.00 psi
CL =   = 0.442
Fbx' = (900)(1.15)(1)(1)(0.442)(1)(1)(1) = 457.5 psi
fb = = 1652.5 psi
 fb = 1652.5 psi > Fbx' = 457.5 psi  (CSI = 3.61)   ➜  NG
fv* = = 50.25 psi
 fv* = 50.25 psi < Fvx' = 207.00 psi  (CSI = 0.24)   ➜  OK
fv = = 50.58 psi
 fv = 50.58 psi < Fvx' = 207.00 psi  (CSI = 0.24)   ➜  OK
Beam Design 2023A57
2/27/2023 5
ΔLL =   =   = 0.49 in.
(L/d)LL = 189.00 / 0.49 = 383
 ΔLL = 0.49 in = L/383 < L/180   ➜  OK
ΔTL =   =   = 0.55 in.
(L/d)TL = 189.00 / 0.55 = 343
 ΔTL = 0.55 in = L/343 < L/120   ➜  OK
fc⊥ = = 126.6 psi
 fc⊥ = 126.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
Beam Design 2023A57
2/27/2023 6
