Size: 3.5 x 16.5
Design Span (L): 15.50 ft.
Clear Span: 15.00 ft.
Total Span: 16.00 ft.
Live Load: 750 plf
Dead Load: 150 plf
Selfweight: 209.9 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 216.6 lbs
Notes: Kitchen and dinning Room wall removal
Beam Design Nick Reichl 2023A55
2/27/2023 1
d = 16.500 in.
A = 3.500 x 16.500 = 57.75 in.2
Sx = (3.500)(16.500)2/6 = 158.81 in.3
Sy = (3.500)2(16.500)/6 = 33.69 in.3
Ix = (3.500)(16.500)3/12 = 1310.20 in.4
Iy = (3.500)3(16.500)/12 = 58.95 in.4
2/27/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (186.00 + 6)] x (12 in./ft.)3 = 6.42 ft3
Volumespan = N[A x L] = 1 x [57.75 x 186.00] x (12 in./ft.)3 = 6.22 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.42 = 216.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.22 = 209.9 lbs
750 plf
150 plf
  ws = 13.54 plf
15.50 ft.
15.00 ft.
7308.32 lbs
7308.32 lbs
2/27/2023 3
fb = = 2073.0 psi
 fb = 2073.0 psi < Fbx' = 2760.0 psi  (CSI = 0.75)   ➜  OK
2/27/2023 4
fv* = = 151.27 psi
 fv* = 151.27 psi < Fvx' = 304.75 psi  (CSI = 0.50)   ➜  OK
fv = = 183.89 psi
 fv = 183.89 psi < Fvx' = 304.75 psi  (CSI = 0.60)   ➜  OK
2/27/2023 5
ΔLL = = 0.41 in.
(L/d)LL = 186.00 / 0.41 = 450
 ΔLL = 0.41 in = L/450 < L/360   ➜  OK
ΔTL = = 0.50 in.
(L/d)TL = 186.00 / 0.50 = 370
 ΔTL = 0.50 in = L/370 < L/240   ➜  OK
fc⊥ = = 348.0 psi
 fc⊥ = 348.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.54)   ➜  OK
2/27/2023 6
