Grade: SPF No.1
Design Span (L): 1.58 ft.
Clear Span: 1.33 ft.
Total Span: 1.83 ft.
Live Load: 0 plf
Dead Load: 103 plf
Selfweight: 2.6 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 3.1 lbs
Orientation: Horizontal
Beam Design 2023A5
1/16/2023 1
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
Beam Design 2023A5
1/16/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (18.96 + 3)] x (12 in./ft.)3 = 0.10 ft3
Volumespan = N[A x L] = 1 x [8.25 x 18.96] x (12 in./ft.)3 = 0.09 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.10 = 3.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.09 = 2.6 lbs
0 plf
103 plf
ws = 1.67 plf
1.58 ft.
1.33 ft.
1.83 ft.
95.77 lbs
95.77 lbs
Beam Design 2023A5
1/16/2023 3
Fby' = (875)(0.9)(1)(1)(1)(1.3)(1.15)(1)(1) = 1177.3 psi
fb = = 190.0 psi
 fb = 190.0 psi < Fby' = 1177.3 psi  (CSI = 0.16)   ➜  OK
Beam Design 2023A5
1/16/2023 4
Fvy' = (135)(0.9)(1)(1)(1) = 121.50 psi
fv* = = 12.66 psi
 fv* = 12.66 psi < Fvy' = 121.50 psi  (CSI = 0.10)   ➜  OK
fv = = 15.03 psi
 fv = 15.03 psi < Fvy' = 121.50 psi  (CSI = 0.12)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(1) = 1400000 psi
Beam Design 2023A5
1/16/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 18.96 / 0.00 = ∞
ΔTL = = 0.01 in.
(L/d)TL = 18.96 / 0.01 = 2798
 ΔTL = 0.01 in = L/2798 < L/240   ➜  OK
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 5.8 psi
 fc⊥ = 5.8 psi < Fc⊥y' = 425.00 psi  (CSI = 0.01)   ➜  OK
Beam Design 2023A5
1/16/2023 6
