Beam Design - Wall Lagging
Size: 4 x 12
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 0 plf
Dead Load: 156 plf
Selfweight: 80.0 lbs
Dist. Selfweight: 9.70 plf
Total Weight: 82.4 lbs
Orientation: Horizontal
Notes: checking reasonableness of lagging span
CF Size Factor 1.1 1 - 1 - -
Beam Design Ed Hultgren 1802 Whitecliff Way, Walnut Creek, CA 94596 NA
2/21/2023 1
2/21/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (99.00 + 3)] x (12 in./ft.)3 = 2.32 ft3
Volumespan = N[A x L] = 1 x [39.38 x 99.00] x (12 in./ft.)3 = 2.26 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.32 = 82.4 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.26 = 80.0 lbs
Distributed Self Weight (ws) = = 9.70 plf
0 plf
156 plf
ws = 9.70 plf
8.25 ft.
8.50 ft.
704.22 lbs
704.22 lbs
2/21/2023 3
Fby' = (900)(0.9)(1)(1)(1)(1.1)(1.1)(1)(1) = 980.1 psi
fb = = 736.5 psi
 fb = 736.5 psi < Fby' = 980.1 psi  (CSI = 0.75)   ➜  OK
2/21/2023 4
Fvy' = (180)(0.9)(0.97)(1)(1) = 157.14 psi
fv* = = 24.20 psi
 fv* = 24.20 psi < Fvy' = 157.14 psi  (CSI = 0.15)   ➜  OK
fv = = 26.04 psi
 fv = 26.04 psi < Fvy' = 157.14 psi  (CSI = 0.17)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1600000(0.9)(1)(1) = 1440000 psi
2/21/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 99.00 / 0.00 = ∞
ΔTL = = 0.30 in.
(L/d)TL = 99.00 / 0.30 = 332
 ΔTL = 0.30 in = L/332 < L/240   ➜  OK
Fc⊥y' = (625)(0.67)(1)(1) = 418.75 psi
Ab = d x lb = 11.25 x 3 = 33.75 in2
fc⊥ = = 20.9 psi
 fc⊥ = 20.9 psi < Fc⊥y' = 418.75 psi  (CSI = 0.05)   ➜  OK
2/21/2023 6
