Beam Design - 2127 Washington Evanston
Grade: SPF SS
Selfweight: 80.1 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 81.8 lbs
Notes: House west window header
Beam Design 2023A45
2/21/2023 1
Beam Design 2023A45
2/21/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 2.81 ft3
Volumespan = N[A x L] = 2 x [16.88 x 141.00] x (12 in./ft.)3 = 2.75 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.81 = 81.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.75 = 80.1 lbs
ws = 6.82 plf
1090.92 lbs
1090.92 lbs
Beam Design 2023A45
2/21/2023 3
fb = = 595.0 psi
 fb = 595.0 psi < Fbx' = 1437.5 psi  (CSI = 0.41)   ➜  OK
Beam Design 2023A45
2/21/2023 4
fv* = = 39.90 psi
 fv* = 39.90 psi < Fvx' = 155.25 psi  (CSI = 0.26)   ➜  OK
fv = = 47.48 psi
 fv = 47.48 psi < Fvx' = 155.25 psi  (CSI = 0.31)   ➜  OK
Beam Design 2023A45
2/21/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 141.00 / 0.08 = 1755
 ΔLL = 0.08 in = L/1755 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 141.00 / 0.15 = 965
 ΔTL = 0.15 in = L/965 < L/240   ➜  OK
fc⊥ = = 121.2 psi
 fc⊥ = 121.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.29)   ➜  OK
Beam Design 2023A45
2/21/2023 6
