Beam Design - house window header
Design Span (L): 11.50 ft.
Clear Span: 11.25 ft.
Total Span: 11.75 ft.
Live Load: 25 plf
Dead Load: 135 plf
Selfweight: 92.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 94.2 lbs
Beam Design 2127 Washington Evanston 2023A43
2/21/2023 1
2/21/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (138.00 + 3)] x (12 in./ft.)3 = 2.75 ft3
Volumespan = N[A x L] = 2 x [16.88 x 138.00] x (12 in./ft.)3 = 2.70 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.75 = 94.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.70 = 92.2 lbs
25 plf
135 plf
ws = 8.02 plf
11.25 ft.
987.10 lbs
987.10 lbs
2/21/2023 3
fb = = 526.7 psi
 fb = 526.7 psi < Fbx' = 1035.0 psi  (CSI = 0.51)   ➜  OK
2/21/2023 4
fv* = = 35.94 psi
 fv* = 35.94 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
fv = = 42.94 psi
 fv = 42.94 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
2/21/2023 5
ΔLL = = 0.02 in.
(L/d)LL = 138.00 / 0.02 = 7989
 ΔLL = 0.02 in = L/7989 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 138.00 / 0.12 = 1189
 ΔTL = 0.12 in = L/1189 < L/240   ➜  OK
fc⊥ = = 109.7 psi
 fc⊥ = 109.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.18)   ➜  OK
2/21/2023 6
