Size: 3.5 x 12
Design Span (L): 26.75 ft.
Clear Span: 26.50 ft.
Total Span: 27.00 ft.
Live Load: 420 plf
Dead Load: 140 plf
Selfweight: 790.2 lbs
Dist. Selfweight: 29.54 plf
Total Weight: 797.6 lbs
Load Duration: 1.33
Beam Design 2023A418
12/18/2023 1
12/18/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [42.00 x (321.00 + 3)] x (12 in./ft.)3 = 23.63 ft3
Volumespan = N[A x L] = 3 x [42.00 x 321.00] x (12 in./ft.)3 = 23.41 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 23.63 = 797.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 23.41 = 790.2 lbs
Distributed Self Weight (ws) = = 29.54 plf
420 plf
140 plf
  ws = 29.54 plf
26.75 ft.
26.50 ft.
27.00 ft.
7958.80 lbs
7958.80 lbs
12/18/2023 3
Fbx' = (2400)(1.33)(1)(1)(1.0) = 3192.0 psi
fb = = 2511.0 psi
 fb = 2511.0 psi < Fbx' = 3192.0 psi  (CSI = 0.79)   ➜  OK
12/18/2023 4
Fvx' = (265)(1.33)(1)(1) = 352.45 psi
fv* = = 86.85 psi
 fv* = 86.85 psi < Fvx' = 352.45 psi  (CSI = 0.25)   ➜  OK
fv = = 93.87 psi
 fv = 93.87 psi < Fvx' = 352.45 psi  (CSI = 0.27)   ➜  OK
12/18/2023 5
ΔLL = = 1.78 in.
(L/d)LL = 321.00 / 1.78 = 181
 ΔLL = 1.78 in = L/181 < L/180   ➜  OK
ΔTL = = 2.50 in.
(L/d)TL = 321.00 / 2.50 = 129
 ΔTL = 2.50 in = L/129 < L/120   ➜  OK
fc⊥ = = 252.7 psi
 fc⊥ = 252.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.39)   ➜  OK
12/18/2023 6
