Beam Design - Garage Header
Size: 3.5 x 9
Design Span (L): 10.83 ft.
Clear Span: 9.67 ft.
Bearing (lb): 14 in.
Selfweight: 80.0 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 88.6 lbs
Beam Design Jim Davis Salt Lake City, UT Reber
12/17/2023 1
d = 9.000 in.
12/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (130.00 + 14)] x (12 in./ft.)3 = 2.62 ft3
Volumespan = N[A x L] = 1 x [31.50 x 130.00] x (12 in./ft.)3 = 2.37 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.62 = 88.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.37 = 80.0 lbs
  ws = 7.39 plf
10.83 ft.
9.67 ft.
1094.28 lbs
1094.28 lbs
12/17/2023 3
fb = = 679.5 psi
 fb = 679.5 psi < Fbx' = 2400.0 psi  (CSI = 0.28)   ➜  OK
12/17/2023 4
fv* = = 40.53 psi
 fv* = 40.53 psi < Fvx' = 265.00 psi  (CSI = 0.15)   ➜  OK
fv = = 47.04 psi
 fv = 47.04 psi < Fvx' = 265.00 psi  (CSI = 0.18)   ➜  OK
12/17/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 130.00 / 0.08 = 1606
 ΔLL = 0.08 in = L/1606 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 130.00 / 0.15 = 880
 ΔTL = 0.15 in = L/880 < L/240   ➜  OK
Ab = b x lb = 3.5 x 14 = 49.00 in2
fc⊥ = = 22.3 psi
 fc⊥ = 22.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.03)   ➜  OK
12/17/2023 6
