Design Span (L): 17.75 ft.
Clear Span: 17.50 ft.
Total Span: 18.00 ft.
Live Load: 0 plf
Dead Load: 105 plf
Selfweight: 142.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 144.3 lbs
Defl. Limits: 480|360
Beam Design 2023A410
11/29/2023 1
11/29/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (213.00 + 3)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 2 x [16.88 x 213.00] x (12 in./ft.)3 = 4.16 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.22 = 144.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.16 = 142.3 lbs
0 plf
105 plf
ws = 8.02 plf
17.75 ft.
17.50 ft.
18.00 ft.
1017.15 lbs
1017.15 lbs
11/29/2023 3
Fbx' = (900)(0.9)(1)(1)(1)(1)(1)(1) = 810.0 psi
fb = = 844.0 psi
 fb = 844.0 psi > Fbx' = 810.0 psi  (CSI = 1.04)   ➜  NG
11/29/2023 4
fv* = = 39.87 psi
 fv* = 39.87 psi < Fvx' = 162.00 psi  (CSI = 0.25)   ➜  OK
fv = = 44.58 psi
 fv = 44.58 psi < Fvx' = 162.00 psi  (CSI = 0.28)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
11/29/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 213.00 / 0.00 = ∞
 ΔLL = 0.00 in = L/∞ < L/480   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 213.00 / 0.44 = 481
 ΔTL = 0.44 in = L/481 < L/360   ➜  OK
fc⊥ = = 113.0 psi
 fc⊥ = 113.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.18)   ➜  OK
11/29/2023 6
