Size: 4 x 8
Design Span (L): 11.50 ft.
Clear Span: 11.00 ft.
Selfweight: 207.9 lbs
Dist. Selfweight: 18.08 plf
Total Weight: 217.0 lbs
Orientation: Horizontal
Beam Design 2023A406
11/12/2023 1
11/12/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [25.38 x (138.00 + 6)] x (12 in./ft.)3 = 6.34 ft3
Volumespan = N[A x L] = 3 x [25.38 x 138.00] x (12 in./ft.)3 = 6.08 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 6.34 = 217.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.08 = 207.9 lbs
Distributed Self Weight (ws) = = 18.08 plf
ws = 18.08 plf
11.00 ft.
1158.49 lbs
1158.49 lbs
11/12/2023 3
Fby' = (900)(1.15)(1)(1)(1)(1.3)(1.05)(1)(1) = 1412.8 psi
fb = = 862.5 psi
 fb = 862.5 psi < Fby' = 1412.8 psi  (CSI = 0.61)   ➜  OK
11/12/2023 4
fv* = = 20.77 psi
 fv* = 20.77 psi < Fvy' = 207.00 psi  (CSI = 0.10)   ➜  OK
fv = = 21.88 psi
 fv = 21.88 psi < Fvy' = 207.00 psi  (CSI = 0.11)   ➜  OK
11/12/2023 5
ΔLL = = 0.32 in.
(L/d)LL = 138.00 / 0.32 = 436
 ΔLL = 0.32 in = L/436 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 138.00 / 0.61 = 226
 ΔTL = 0.61 in = L/226 > L/240   ➜  NG
Ab = d x lb = 7.25 x 6 = 43.50 in2
fc⊥ = = 8.9 psi
 fc⊥ = 8.9 psi < Fc⊥y' = 625.00 psi  (CSI = 0.01)   ➜  OK
11/12/2023 6
