Size: 4 x 6
Design Span (L): 8.08 ft.
Clear Span: 7.67 ft.
Total Span: 8.50 ft.
Bearing (lb): 5 in.
Live Load: 500 plf
Selfweight: 73.9 lbs
Dist. Selfweight: 9.14 plf
Total Weight: 77.7 lbs
Beam Design 2023A401
10/30/2023 1
10/30/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [19.25 x (97.00 + 5)] x (12 in./ft.)3 = 2.27 ft3
Volumespan = N[A x L] = 2 x [19.25 x 97.00] x (12 in./ft.)3 = 2.16 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.27 = 77.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.16 = 73.9 lbs
Distributed Self Weight (ws) = = 9.14 plf
500 plf
ws = 9.14 plf
8.08 ft.
7.67 ft.
8.50 ft.
2482.52 lbs
2482.52 lbs
10/30/2023 3
fb = = 1622.1 psi
 fb = 1622.1 psi > Fbx' = 1345.5 psi  (CSI = 1.21)   ➜  NG
10/30/2023 4
fv* = = 81.55 psi
 fv* = 81.55 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
fv = = 91.98 psi
 fv = 91.98 psi < Fvx' = 207.00 psi  (CSI = 0.44)   ➜  OK
10/30/2023 5
ΔLL = = 0.31 in.
(L/d)LL = 97.00 / 0.31 = 314
 ΔLL = 0.31 in = L/314 > L/360   ➜  NG
ΔTL = = 0.36 in.
(L/d)TL = 97.00 / 0.36 = 268
 ΔTL = 0.36 in = L/268 < L/240   ➜  OK
Ab = b x lb = 3.5 x 5 = 17.50 in2
fc⊥ = = 70.9 psi
 fc⊥ = 70.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
10/30/2023 6
