Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 40 plf
Dead Load: 14 plf
Selfweight: 88.8 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 90.2 lbs
Beam Design 2023A4
1/15/2023 1
Beam Design 2023A4
1/15/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (189.00 + 3)] x (12 in./ft.)3 = 2.42 ft3
Volumespan = N[A x L] = 2 x [10.88 x 189.00] x (12 in./ft.)3 = 2.38 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.42 = 90.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.38 = 88.8 lbs
40 plf
14 plf
ws = 5.64 plf
15.75 ft.
15.50 ft.
477.11 lbs
477.11 lbs
Beam Design 2023A4
1/15/2023 3
Fbx' = (925)(1.00)(1)(1)(1)(1)(1)(1) = 925.0 psi
fb = = 844.4 psi
 fb = 844.4 psi < Fbx' = 925.0 psi  (CSI = 0.91)   ➜  OK
Beam Design 2023A4
1/15/2023 4
fv* = = 29.90 psi
 fv* = 29.90 psi < Fvx' = 175.00 psi  (CSI = 0.17)   ➜  OK
fv = = 32.39 psi
 fv = 32.39 psi < Fvx' = 175.00 psi  (CSI = 0.19)   ➜  OK
Beam Design 2023A4
1/15/2023 5
ΔLL = = 0.42 in.
(L/d)LL = 189.00 / 0.42 = 455
 ΔLL = 0.42 in = L/455 < L/360   ➜  OK
ΔTL = = 0.62 in.
(L/d)TL = 189.00 / 0.62 = 305
 ΔTL = 0.62 in = L/305 < L/240   ➜  OK
fc⊥ = = 53.0 psi
 fc⊥ = 53.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2023A4
1/15/2023 6
