Design Span (L): 15.88 ft.
Clear Span: 15.75 ft.
Total Span: 16.00 ft.
Bearing (lb): 1.5 in.
Live Load: 50 plf
Dead Load: 5 plf
Selfweight: 57.1 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 57.6 lbs
Beam Design 2023A396
10/26/2023 1
10/26/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (190.50 + 1.5)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 1 x [13.88 x 190.50] x (12 in./ft.)3 = 1.53 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.54 = 57.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.53 = 57.1 lbs
50 plf
5 plf
ws = 3.60 plf
15.88 ft.
15.75 ft.
468.78 lbs
468.78 lbs
10/26/2023 3
Fbx' = (800)(1.00)(1)(1)(1)(1)(1)(1.15) = 920.0 psi
fb = = 1035.5 psi
 fb = 1035.5 psi > Fbx' = 920.0 psi  (CSI = 1.13)   ➜  NG
10/26/2023 4
fv* = = 45.40 psi
 fv* = 45.40 psi < Fvx' = 175.00 psi  (CSI = 0.26)   ➜  OK
fv = = 50.28 psi
 fv = 50.28 psi < Fvx' = 175.00 psi  (CSI = 0.29)   ➜  OK
10/26/2023 5
ΔLL = = 0.52 in.
(L/d)LL = 190.50 / 0.52 = 369
 ΔLL = 0.52 in = L/369 < L/360   ➜  OK
ΔTL = = 0.60 in.
(L/d)TL = 190.50 / 0.60 = 315
 ΔTL = 0.60 in = L/315 < L/240   ➜  OK
fc⊥ = = 208.3 psi
 fc⊥ = 208.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.37)   ➜  OK
10/26/2023 6
