Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Dead Load: 10 plf
Selfweight: 56.7 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 57.6 lbs
Beam Design 2023A393
10/25/2023 1
10/25/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (189.00 + 3)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 1 x [13.88 x 189.00] x (12 in./ft.)3 = 1.52 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.54 = 57.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.52 = 56.7 lbs
10 plf
ws = 3.60 plf
15.75 ft.
15.50 ft.
908.78 lbs
908.78 lbs
10/25/2023 3
Fbx' = (800)(1.00)(1)(1)(1)(1)(1)(1) = 800.0 psi
fb = = 1976.0 psi
 fb = 1976.0 psi > Fbx' = 800.0 psi  (CSI = 2.47)   ➜  NG
10/25/2023 4
fv* = = 87.24 psi
 fv* = 87.24 psi < Fvx' = 175.00 psi  (CSI = 0.50)   ➜  OK
fv = = 96.71 psi
 fv = 96.71 psi < Fvx' = 175.00 psi  (CSI = 0.55)   ➜  OK
10/25/2023 5
ΔLL = = 1.00 in.
(L/d)LL = 189.00 / 1.00 = 189
 ΔLL = 1.00 in = L/189 > L/360   ➜  NG
ΔTL = = 1.14 in.
(L/d)TL = 189.00 / 1.14 = 166
 ΔTL = 1.14 in = L/166 > L/240   ➜  NG
fc⊥ = = 202.0 psi
 fc⊥ = 202.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.36)   ➜  OK
10/25/2023 6
