Grade: SP No.1
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Quantity (N): 4
Live Load: 563.42 plf
Dead Load: 105.82 plf
Selfweight: 284.3 lbs
Dist. Selfweight: 17.50 plf
Total Weight: 288.7 lbs
Beam Design MANOR 408 GOLFVIEW 2023A392
10/25/2023 1
10/25/2023 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 7.73 ft3
Volumespan = N[A x L] = 4 x [16.88 x 195.00] x (12 in./ft.)3 = 7.62 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 7.73 = 288.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 7.62 = 284.3 lbs
Distributed Self Weight (ws) = = 17.50 plf
563.42 plf
105.82 plf
ws = 17.50 plf
16.25 ft.
16.50 ft.
5665.59 lbs
5665.59 lbs
10/25/2023 3
fb = = 2149.2 psi
 fb = 2149.2 psi > Fbx' = 1150.0 psi  (CSI = 1.87)   ➜  NG
10/25/2023 4
fv* = = 109.69 psi
 fv* = 109.69 psi < Fvx' = 201.25 psi  (CSI = 0.55)   ➜  OK
fv = = 123.99 psi
 fv = 123.99 psi < Fvx' = 201.25 psi  (CSI = 0.62)   ➜  OK
10/25/2023 5
ΔLL = = 0.78 in.
(L/d)LL = 195.00 / 0.78 = 251
 ΔLL = 0.78 in = L/251 < L/240   ➜  OK
ΔTL = = 0.95 in.
(L/d)TL = 195.00 / 0.95 = 206
 ΔTL = 0.95 in = L/206 < L/180   ➜  OK
fc⊥ = = 314.8 psi
 fc⊥ = 314.8 psi < Fc⊥x' = 565.00 psi  (CSI = 0.56)   ➜  OK
10/25/2023 6
