Size: 3.125 x 7.5
Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Selfweight: 37.1 lbs
Dist. Selfweight: 5.49 plf
Total Weight: 38.5 lbs
CL Beam Stability Factor 0.978 - - - - -
Beam Design 2023A390
10/23/2023 1
b = 3.125 in.
d = 7.500 in.
A = 3.125 x 7.500 = 23.44 in.2
Sx = (3.125)(7.500)2/6 = 29.30 in.3
Sy = (3.125)2(7.500)/6 = 12.21 in.3
Ix = (3.125)(7.500)3/12 = 109.86 in.4
Iy = (3.125)3(7.500)/12 = 19.07 in.4
10/23/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [23.44 x (81.00 + 3)] x (12 in./ft.)3 = 1.14 ft3
Volumespan = N[A x L] = 1 x [23.44 x 81.00] x (12 in./ft.)3 = 1.10 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.14 = 38.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.10 = 37.1 lbs
Distributed Self Weight (ws) = = 5.49 plf
  ws = 5.49 plf
6.75 ft.
6.50 ft.
7.00 ft.
631.73 lbs
631.73 lbs
10/23/2023 3
lu = Unbraced Length = 6.750 ft.
lu/d = = 10.80
le = 1.63lu + 3d = 1.63(81.0) + 3(7.5) = 154.53 in. = 12.88 ft.  (NDS Table 3.3.3)
Rb = = 10.89
 Rb = 10.89 < 50   ➜  OK
10/23/2023 4
FbE = = 8594.61 psi
CL =   = 0.978
CL = 0.978 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.978) = 2698.3 psi
fb = = 421.1 psi
 fb = 421.1 psi < Fbx' = 2698.3 psi  (CSI = 0.16)   ➜  OK
fv* = = 31.77 psi
10/23/2023 5
 fv* = 31.77 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
fv = = 38.99 psi
 fv = 38.99 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
ΔLL = = 0.02 in.
(L/d)LL = 81.00 / 0.02 = 3429
 ΔLL = 0.02 in = L/3429 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 81.00 / 0.04 = 1900
 ΔTL = 0.04 in = L/1900 < L/240   ➜  OK
10/23/2023 6
fc⊥ = = 67.4 psi
 fc⊥ = 67.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.10)   ➜  OK
10/23/2023 7
