Design Span (L): 7.96 ft.
Clear Span: 7.67 ft.
Total Span: 8.25 ft.
Bearing (lb): 3.5 in.
Live Load: 502 plf
Dead Load: 126 plf
Selfweight: 63.8 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 66.1 lbs
CL Beam Stability Factor 0.979 - - - - -
Beam Design 2023A39
2/20/2023 1
Beam Design 2023A39
2/20/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (95.50 + 3.5)] x (12 in./ft.)3 = 1.93 ft3
Volumespan = N[A x L] = 2 x [16.88 x 95.50] x (12 in./ft.)3 = 1.87 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.93 = 66.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.87 = 63.8 lbs
502 plf
126 plf
ws = 8.02 plf
7.96 ft.
7.67 ft.
8.25 ft.
2623.46 lbs
2623.46 lbs
Beam Design 2023A39
2/20/2023 3
lu = Unbraced Length = 7.958 ft.
lu/d = = 8.49
le = 1.63lu + 3d = 1.63(95.5) + 3(11.25) = 189.41 in. = 15.78 ft.  (NDS Table 3.3.3)
Rb = = 15.39
 Rb = 15.39 < 50   ➜  OK
Beam Design 2023A39
2/20/2023 4
FbE = = 2939.68 psi
CL =   = 0.979
Fbx' = (900)(1.00)(1)(1)(0.979)(1)(1)(1) = 881.1 psi
fb = = 954.8 psi
 fb = 954.8 psi > Fbx' = 881.1 psi  (CSI = 1.08)   ➜  NG
fv* = = 85.98 psi
 fv* = 85.98 psi < Fvx' = 180.00 psi  (CSI = 0.48)   ➜  OK
fv = = 112.48 psi
 fv = 112.48 psi < Fvx' = 180.00 psi  (CSI = 0.62)   ➜  OK
Beam Design 2023A39
2/20/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 95.50 / 0.08 = 1201
 ΔLL = 0.08 in = L/1201 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 95.50 / 0.10 = 948
 ΔTL = 0.10 in = L/948 < L/240   ➜  OK
fc⊥ = = 249.9 psi
 fc⊥ = 249.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.40)   ➜  OK
Beam Design 2023A39
2/20/2023 6
