Beam Design - glulam beam
Grade: 24F-V3 1.8E SP/SP
Size: 2.5 x 11
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 145.5 lbs
Dist. Selfweight: 7.37 plf
Total Weight: 147.4 lbs
Beam Design 1503 Menlo Menlo Porch
10/21/2023 1
b = 2.500 in.
d = 11.000 in.
A = 2.500 x 11.000 = 27.50 in.2
Sx = (2.500)(11.000)2/6 = 50.42 in.3
Sy = (2.500)2(11.000)/6 = 11.46 in.3
Ix = (2.500)(11.000)3/12 = 277.29 in.4
Iy = (2.500)3(11.000)/12 = 14.32 in.4
10/21/2023 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [27.50 x (237.00 + 3)] x (12 in./ft.)3 = 3.82 ft3
Volumespan = N[A x L] = 1 x [27.50 x 237.00] x (12 in./ft.)3 = 3.77 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.82 = 147.4 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.77 = 145.5 lbs
Distributed Self Weight (ws) = = 7.37 plf
40 plf
10 plf
  ws = 7.37 plf
19.75 ft.
19.50 ft.
573.68 lbs
573.68 lbs
10/21/2023 3
fb = = 665.8 psi
 fb = 665.8 psi < Fbx' = 2208.0 psi  (CSI = 0.30)   ➜  OK
10/21/2023 4
Fvx' = (300)(1.15)(0.875)(1) = 301.88 psi
fv* = = 28.03 psi
 fv* = 28.03 psi < Fvx' = 301.88 psi  (CSI = 0.09)   ➜  OK
fv = = 30.90 psi
 fv = 30.90 psi < Fvx' = 301.88 psi  (CSI = 0.10)   ➜  OK
10/21/2023 5
ΔLL = = 0.33 in.
(L/d)LL = 237.00 / 0.33 = 720
 ΔLL = 0.33 in = L/720 < L/360   ➜  OK
ΔTL = = 0.47 in.
(L/d)TL = 237.00 / 0.47 = 502
 ΔTL = 0.47 in = L/502 < L/240   ➜  OK
Fc⊥x' = (740)(0.53)(1) = 392.20 psi
fc⊥ = = 76.5 psi
 fc⊥ = 76.5 psi < Fc⊥x' = 392.20 psi  (CSI = 0.20)   ➜  OK
10/21/2023 6
