Beam Design - Menlo Porch
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 178.6 lbs
Dist. Selfweight: 9.04 plf
Total Weight: 180.9 lbs
Beam Design 1503 Menlo Place 23-120
10/21/2023 1
10/21/2023 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 4.69 ft3
Volumespan = N[A x L] = 2 x [16.88 x 237.00] x (12 in./ft.)3 = 4.63 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 4.69 = 180.9 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 4.63 = 178.6 lbs
Distributed Self Weight (ws) = = 9.04 plf
40 plf
10 plf
ws = 9.04 plf
19.75 ft.
19.50 ft.
590.43 lbs
590.43 lbs
10/21/2023 3
fb = = 545.9 psi
 fb = 545.9 psi < Fbx' = 862.5 psi  (CSI = 0.63)   ➜  OK
10/21/2023 4
fv* = = 23.45 psi
 fv* = 23.45 psi < Fvx' = 195.21 psi  (CSI = 0.12)   ➜  OK
fv = = 25.91 psi
 fv = 25.91 psi < Fvx' = 195.21 psi  (CSI = 0.13)   ➜  OK
10/21/2023 5
ΔLL = = 0.31 in.
(L/d)LL = 237.00 / 0.31 = 776
 ΔLL = 0.31 in = L/776 < L/180   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 237.00 / 0.45 = 526
 ΔTL = 0.45 in = L/526 < L/120   ➜  OK
fc⊥ = = 65.6 psi
 fc⊥ = 65.6 psi < Fc⊥x' = 378.55 psi  (CSI = 0.17)   ➜  OK
10/21/2023 6
