Beam Design - Garage Header
Size: 3.5 x 9
Design Span (L): 17.75 ft.
Clear Span: 17.50 ft.
Total Span: 18.00 ft.
Selfweight: 131.1 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 132.9 lbs
Beam Design Jim Davis Reber
10/17/2023 1
d = 9.000 in.
10/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (213.00 + 3)] x (12 in./ft.)3 = 3.94 ft3
Volumespan = N[A x L] = 1 x [31.50 x 213.00] x (12 in./ft.)3 = 3.88 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.94 = 132.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.88 = 131.1 lbs
  ws = 7.39 plf
17.75 ft.
17.50 ft.
18.00 ft.
1641.47 lbs
1641.47 lbs
10/17/2023 3
fb = = 1824.2 psi
 fb = 1824.2 psi < Fbx' = 2760.0 psi  (CSI = 0.66)   ➜  OK
10/17/2023 4
fv* = = 70.57 psi
 fv* = 70.57 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 77.08 psi
 fv = 77.08 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
10/17/2023 5
ΔLL = = 0.58 in.
(L/d)LL = 213.00 / 0.58 = 365
 ΔLL = 0.58 in = L/365 < L/360   ➜  OK
ΔTL = = 1.06 in.
(L/d)TL = 213.00 / 1.06 = 200
 ΔTL = 1.06 in = L/200 > L/240   ➜  NG
fc⊥ = = 156.3 psi
 fc⊥ = 156.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.24)   ➜  OK
10/17/2023 6
