Beam Design - 13844 SW 162nd Ter
Size: 5.5 x 9
Design Span (L): 9.50 ft.
Clear Span: 9.25 ft.
Total Span: 9.75 ft.
Live Load: 500 plf
Dead Load: 280 plf
Selfweight: 110.3 lbs
Dist. Selfweight: 11.61 plf
Total Weight: 113.2 lbs
Beam Design Juan Diaz 2023A380
10/8/2023 1
d = 9.000 in.
10/8/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (114.00 + 3)] x (12 in./ft.)3 = 3.35 ft3
Volumespan = N[A x L] = 1 x [49.50 x 114.00] x (12 in./ft.)3 = 3.27 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.35 = 113.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.27 = 110.3 lbs
Distributed Self Weight (ws) = = 11.61 plf
500 plf
280 plf
  ws = 11.61 plf
9.50 ft.
9.25 ft.
9.75 ft.
3859.08 lbs
3859.08 lbs
10/8/2023 3
fb = = 1443.3 psi
 fb = 1443.3 psi < Fbx' = 2760.0 psi  (CSI = 0.52)   ➜  OK
10/8/2023 4
fv* = = 95.95 psi
 fv* = 95.95 psi < Fvx' = 304.75 psi  (CSI = 0.31)   ➜  OK
fv = = 113.94 psi
 fv = 113.94 psi < Fvx' = 304.75 psi  (CSI = 0.37)   ➜  OK
10/8/2023 5
ΔLL = = 0.15 in.
(L/d)LL = 114.00 / 0.15 = 748
 ΔLL = 0.15 in = L/748 < L/180   ➜  OK
ΔTL = = 0.24 in.
(L/d)TL = 114.00 / 0.24 = 473
 ΔTL = 0.24 in = L/473 < L/120   ➜  OK
fc⊥ = = 233.9 psi
 fc⊥ = 233.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.36)   ➜  OK
10/8/2023 6
