Design Span (L): 8.00 ft.
Clear Span: 7.71 ft.
Total Span: 8.29 ft.
Bearing (lb): 3.5 in.
Live Load: 502 plf
Dead Load: 126 plf
Selfweight: 79.1 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 82.0 lbs
Beam Design 2023A38
2/20/2023 1
Beam Design 2023A38
2/20/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (96.00 + 3.5)] x (12 in./ft.)3 = 2.40 ft3
Volumespan = N[A x L] = 3 x [13.88 x 96.00] x (12 in./ft.)3 = 2.31 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.40 = 82.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.31 = 79.1 lbs
502 plf
126 plf
ws = 9.89 plf
7.71 ft.
8.29 ft.
2644.57 lbs
2644.57 lbs
Beam Design 2023A38
2/20/2023 3
lu = Unbraced Length = 8 ft.
lu/d = = 10.38
le = 1.63lu + 3d = 1.63(96.0) + 3(9.25) = 184.23 in. = 15.35 ft.  (NDS Table 3.3.3)
Rb = = 9.17
 Rb = 9.17 < 50   ➜  OK
Beam Design 2023A38
2/20/2023 4
FbE = = 8270.51 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.1)(1)(1) = 990.00 psi
CL =   = 0.993
Fbx' = (900)(1.00)(1)(1)(0.993)(1.1)(1)(1) = 983.4 psi
fb = = 954.3 psi
 fb = 954.3 psi < Fbx' = 983.4 psi  (CSI = 0.97)   ➜  OK
fv* = = 74.23 psi
 fv* = 74.23 psi < Fvx' = 180.00 psi  (CSI = 0.41)   ➜  OK
fv = = 91.95 psi
 fv = 91.95 psi < Fvx' = 180.00 psi  (CSI = 0.51)   ➜  OK
Beam Design 2023A38
2/20/2023 5
ΔLL = = 0.10 in.
(L/d)LL = 96.00 / 0.10 = 985
 ΔLL = 0.10 in = L/985 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 96.00 / 0.12 = 775
 ΔTL = 0.12 in = L/775 < L/240   ➜  OK
fc⊥ = = 167.9 psi
 fc⊥ = 167.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.27)   ➜  OK
Beam Design 2023A38
2/20/2023 6
