Species: Redwood
Grade: RW SS
Size: 4 x 12
Design Span (L): 8.57 ft.
Clear Span: 8.45 ft.
Total Span: 8.70 ft.
Bearing (lb): 1.5 in.
Live Load: 300 plf
Dead Load: 400 plf
Selfweight: 71.2 lbs
Dist. Selfweight: 8.31 plf
Total Weight: 72.3 lbs
Load Duration: 1.60
CF Size Factor 1.1 1 - 1 - -
Beam Design 2023A376
10/3/2023 1
RW SS 1350 800 160 650 1500 1400000 510000 0.44
G = 0.44
10/3/2023 2
= 30.39 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (102.90 + 1.5)] x (12 in./ft.)3 = 2.38 ft3
Volumespan = N[A x L] = 1 x [39.38 x 102.90] x (12 in./ft.)3 = 2.34 ft3
Total Weight (WT) = ρw x Volumetotal = 30.39 x 2.38 = 72.3 lbs
Self Weight (WS) = ρw x Volumespan = 30.39 x 2.34 = 71.2 lbs
Distributed Self Weight (ws) = = 8.31 plf
300 plf
400 plf
ws = 8.31 plf
8.57 ft.
8.45 ft.
8.70 ft.
3081.14 lbs
3081.14 lbs
10/3/2023 3
Fbx' = (1350)(1.60)(1)(1)(1)(1.1)(1)(1) = 2376.0 psi
fb = = 1058.2 psi
 fb = 1058.2 psi < Fbx' = 2376.0 psi  (CSI = 0.45)   ➜  OK
10/3/2023 4
Fvx' = (160)(1.60)(1)(1)(1) = 256.00 psi
fv* = = 90.39 psi
 fv* = 90.39 psi < Fvx' = 256.00 psi  (CSI = 0.35)   ➜  OK
fv = = 115.69 psi
 fv = 115.69 psi < Fvx' = 256.00 psi  (CSI = 0.45)   ➜  OK
10/3/2023 5
ΔLL = = 0.06 in.
(L/d)LL = 102.90 / 0.06 = 1639
 ΔLL = 0.06 in = L/1639 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 102.90 / 0.15 = 694
 ΔTL = 0.15 in = L/694 < L/240   ➜  OK
Fc⊥x' = (650)(1)(1)(1) = 650.00 psi
Ab = b x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 586.9 psi
 fc⊥ = 586.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.90)   ➜  OK
10/3/2023 6
