Grade: 24F-V3 1.8E SP/SP
Size: 3 x 12.375
Design Span (L): 27.75 ft.
Clear Span: 27.50 ft.
Total Span: 28.00 ft.
Live Load: 20 plf
Dead Load: 25 plf
Selfweight: 263.9 lbs
Dist. Selfweight: 9.51 plf
Total Weight: 266.3 lbs
Load Duration: 1.33
Beam Design 2023A375
10/2/2023 1
b = 3.000 in.
d = 12.375 in.
A = 3.000 x 12.375 = 37.13 in.2
Sx = (3.000)(12.375)2/6 = 76.57 in.3
Sy = (3.000)2(12.375)/6 = 18.56 in.3
Ix = (3.000)(12.375)3/12 = 473.78 in.4
Iy = (3.000)3(12.375)/12 = 27.84 in.4
10/2/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [37.13 x (333.00 + 3)] x (12 in./ft.)3 = 7.22 ft3
Volumespan = N[A x L] = 1 x [37.13 x 333.00] x (12 in./ft.)3 = 7.15 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 7.22 = 266.3 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 7.15 = 263.9 lbs
Distributed Self Weight (ws) = = 9.51 plf
20 plf
25 plf
  ws = 9.51 plf
27.75 ft.
27.50 ft.
28.00 ft.
763.15 lbs
763.15 lbs
10/2/2023 3
Fbx' = (2400)(1.33)(1)(1)(1.0) = 3192.0 psi
fb = = 822.3 psi
 fb = 822.3 psi < Fbx' = 3192.0 psi  (CSI = 0.26)   ➜  OK
10/2/2023 4
Fvx' = (300)(1.33)(1)(1) = 399.00 psi
fv* = = 28.29 psi
 fv* = 28.29 psi < Fvx' = 399.00 psi  (CSI = 0.07)   ➜  OK
fv = = 30.56 psi
 fv = 30.56 psi < Fvx' = 399.00 psi  (CSI = 0.08)   ➜  OK
10/2/2023 5
ΔLL = = 0.31 in.
(L/d)LL = 333.00 / 0.31 = 1064
 ΔLL = 0.31 in = L/1064 < L/360   ➜  OK
ΔTL = = 0.85 in.
(L/d)TL = 333.00 / 0.85 = 390
 ΔTL = 0.85 in = L/390 < L/240   ➜  OK
Ab = b x lb = 3 x 3 = 9.00 in2
fc⊥ = = 84.8 psi
 fc⊥ = 84.8 psi < Fc⊥x' = 740.00 psi  (CSI = 0.11)   ➜  OK
10/2/2023 6
