Species: Redwood
Grade: RW CS
Size: 4 x 12
Design Span (L): 8.58 ft.
Clear Span: 8.33 ft.
Total Span: 8.83 ft.
Live Load: 300 plf
Dead Load: 250 plf
Selfweight: 71.3 lbs
Dist. Selfweight: 8.31 plf
Total Weight: 73.4 lbs
Load Duration: 1.60
CF Size Factor 1.1 1 - 1 - -
Beam Design 2023A371
9/27/2023 1
RW CS 1750 1000 160 650 1850 1400000 510000 0.44
G = 0.44
9/27/2023 2
= 30.39 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (102.96 + 3)] x (12 in./ft.)3 = 2.41 ft3
Volumespan = N[A x L] = 1 x [39.38 x 102.96] x (12 in./ft.)3 = 2.35 ft3
Total Weight (WT) = ρw x Volumetotal = 30.39 x 2.41 = 73.4 lbs
Self Weight (WS) = ρw x Volumespan = 30.39 x 2.35 = 71.3 lbs
Distributed Self Weight (ws) = = 8.31 plf
300 plf
250 plf
ws = 8.31 plf
8.58 ft.
8.33 ft.
8.83 ft.
2464.93 lbs
2464.93 lbs
9/27/2023 3
Fbx' = (1750)(1.60)(1)(1)(1)(1.1)(1)(1) = 3080.0 psi
fb = = 835.1 psi
 fb = 835.1 psi < Fbx' = 3080.0 psi  (CSI = 0.27)   ➜  OK
9/27/2023 4
Fvx' = (160)(1.60)(1)(1)(1) = 256.00 psi
fv* = = 71.30 psi
 fv* = 71.30 psi < Fvx' = 256.00 psi  (CSI = 0.28)   ➜  OK
fv = = 91.24 psi
 fv = 91.24 psi < Fvx' = 256.00 psi  (CSI = 0.36)   ➜  OK
9/27/2023 5
ΔLL = = 0.06 in.
(L/d)LL = 102.96 / 0.06 = 1636
 ΔLL = 0.06 in = L/1636 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 102.96 / 0.12 = 879
 ΔTL = 0.12 in = L/879 < L/240   ➜  OK
Fc⊥x' = (650)(1)(1)(1) = 650.00 psi
fc⊥ = = 234.8 psi
 fc⊥ = 234.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.36)   ➜  OK
9/27/2023 6
