Size: 2 x 14
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 0 plf
Dead Load: 602 plf
Selfweight: 73.2 lbs
Dist. Selfweight: 9.44 plf
Total Weight: 75.5 lbs
CF Size Factor 0.9 0.9 - 0.9 - -
Beam Design Joe Conrad Dewitt Conrad
9/24/2023 1
d = 13.250 in.
A = 1.500 x 13.250 = 19.88 in.2
Sx = (1.500)(13.250)2/6 = 43.89 in.3
Sy = (1.500)2(13.250)/6 = 4.97 in.3
Ix = (1.500)(13.250)3/12 = 290.78 in.4
Iy = (1.500)3(13.250)/12 = 3.73 in.4
9/24/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [19.88 x (93.00 + 3)] x (12 in./ft.)3 = 2.21 ft3
Volumespan = N[A x L] = 2 x [19.88 x 93.00] x (12 in./ft.)3 = 2.14 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.21 = 75.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.14 = 73.2 lbs
Distributed Self Weight (ws) = = 9.44 plf
0 plf
602 plf
ws = 9.44 plf
7.75 ft.
7.50 ft.
2445.77 lbs
2445.77 lbs
9/24/2023 3
Fbx' = (900)(0.9)(1)(1)(1)(0.9)(1)(1) = 729.0 psi
fb = = 627.5 psi
 fb = 627.5 psi < Fbx' = 729.0 psi  (CSI = 0.86)   ➜  OK
9/24/2023 4
fv* = = 63.93 psi
 fv* = 63.93 psi < Fvx' = 162.00 psi  (CSI = 0.39)   ➜  OK
fv = = 89.41 psi
 fv = 89.41 psi < Fvx' = 162.00 psi  (CSI = 0.55)   ➜  OK
9/24/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 93.00 / 0.00 = ∞
ΔTL = = 0.05 in.
(L/d)TL = 93.00 / 0.05 = 1744
 ΔTL = 0.05 in = L/1744 < L/240   ➜  OK
fc⊥ = = 271.8 psi
 fc⊥ = 271.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.43)   ➜  OK
9/24/2023 6
