Size: 3.125 x 6
Design Span (L): 9.75 ft.
Clear Span: 9.25 ft.
Total Span: 10.25 ft.
Selfweight: 42.9 lbs
Dist. Selfweight: 4.40 plf
Total Weight: 45.1 lbs
CL Beam Stability Factor 0.975 - - - - -
Beam Design 2023A368
9/22/2023 1
b = 3.125 in.
d = 6.000 in.
A = 3.125 x 6.000 = 18.75 in.2
Sx = (3.125)(6.000)2/6 = 18.75 in.3
Sy = (3.125)2(6.000)/6 = 9.77 in.3
Ix = (3.125)(6.000)3/12 = 56.25 in.4
Iy = (3.125)3(6.000)/12 = 15.26 in.4
9/22/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [18.75 x (117.00 + 6)] x (12 in./ft.)3 = 1.33 ft3
Volumespan = N[A x L] = 1 x [18.75 x 117.00] x (12 in./ft.)3 = 1.27 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.33 = 45.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.27 = 42.9 lbs
Distributed Self Weight (ws) = = 4.40 plf
  ws = 4.40 plf
9.75 ft.
9.25 ft.
10.25 ft.
919.40 lbs
919.40 lbs
9/22/2023 3
lu = Unbraced Length = 9.750 ft.
lu/d = = 19.50
le = 1.63lu + 3d = 1.63(117.0) + 3(6) = 208.71 in. = 17.39 ft.  (NDS Table 3.3.3)
Rb = = 11.32
 Rb = 11.32 < 50   ➜  OK
9/22/2023 4
FbE = = 7954.37 psi
CL =   = 0.975
CL = 0.975 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.975) = 2691.2 psi
fb = = 1364.3 psi
 fb = 1364.3 psi < Fbx' = 2691.2 psi  (CSI = 0.51)   ➜  OK
fv* = = 62.79 psi
9/22/2023 5
 fv* = 62.79 psi < Fvx' = 304.75 psi  (CSI = 0.21)   ➜  OK
fv = = 69.96 psi
 fv = 69.96 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
ΔLL = = 0.20 in.
(L/d)LL = 117.00 / 0.20 = 583
 ΔLL = 0.20 in = L/583 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 117.00 / 0.36 = 325
 ΔTL = 0.36 in = L/325 < L/240   ➜  OK
9/22/2023 6
Ab = b x lb = 3.125 x 6 = 18.75 in2
fc⊥ = = 49.0 psi
 fc⊥ = 49.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.08)   ➜  OK
9/22/2023 7
