Size: 5.5 x 16.5
Design Span (L): 18.58 ft.
Clear Span: 18.17 ft.
Total Span: 19.00 ft.
Bearing (lb): 5 in.
Live Load: 220 plf
Dead Load: 165 plf
Selfweight: 395.4 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 404.2 lbs
Defl. Limits: 720|480
CV Volume Factor 0.974b - - - - -
Beam Design lot 21 sahhali pt sahhali lot 21
9/22/2023 1
d = 16.500 in.
9/22/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (223.00 + 5)] x (12 in./ft.)3 = 11.97 ft3
Volumespan = N[A x L] = 1 x [90.75 x 223.00] x (12 in./ft.)3 = 11.71 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.97 = 404.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.71 = 395.4 lbs
220 plf
165 plf
  ws = 21.28 plf
18.58 ft.
18.17 ft.
19.00 ft.
3859.56 lbs
3859.56 lbs
9/22/2023 3
CV = = 0.974
CV = 0.974 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.974) = 2336.8 psi
fb = = 843.3 psi
 fb = 843.3 psi < Fbx' = 2336.8 psi  (CSI = 0.36)   ➜  OK
9/22/2023 4
fv* = = 53.16 psi
 fv* = 53.16 psi < Fvx' = 265.00 psi  (CSI = 0.20)   ➜  OK
fv = = 62.40 psi
 fv = 62.40 psi < Fvx' = 265.00 psi  (CSI = 0.24)   ➜  OK
LL Allowable: L/720
TL Allowable: L/480
9/22/2023 5
ΔLL = = 0.16 in.
(L/d)LL = 223.00 / 0.16 = 1400
 ΔLL = 0.16 in = L/1400 < L/720   ➜  OK
ΔTL = = 0.29 in.
(L/d)TL = 223.00 / 0.29 = 758
 ΔTL = 0.29 in = L/758 < L/480   ➜  OK
Ab = b x lb = 5.5 x 5 = 27.50 in2
fc⊥ = = 140.3 psi
 fc⊥ = 140.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
9/22/2023 6
