Size: 5.5 x 12
Design Span (L): 18.58 ft.
Clear Span: 18.17 ft.
Total Span: 19.00 ft.
Bearing (lb): 5 in.
Live Load: 220 plf
Dead Load: 165 plf
Selfweight: 287.6 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 294.0 lbs
Defl. Limits: 720|480
Beam Design sahhali lot 21
9/22/2023 1
9/22/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (223.00 + 5)] x (12 in./ft.)3 = 8.71 ft3
Volumespan = N[A x L] = 1 x [66.00 x 223.00] x (12 in./ft.)3 = 8.52 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.71 = 294.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.52 = 287.6 lbs
220 plf
165 plf
  ws = 15.47 plf
18.58 ft.
18.17 ft.
19.00 ft.
3804.44 lbs
3804.44 lbs
9/22/2023 3
fb = = 1571.5 psi
 fb = 1571.5 psi < Fbx' = 2400.0 psi  (CSI = 0.65)   ➜  OK
9/22/2023 4
fv* = = 75.47 psi
 fv* = 75.47 psi < Fvx' = 265.00 psi  (CSI = 0.28)   ➜  OK
fv = = 84.57 psi
 fv = 84.57 psi < Fvx' = 265.00 psi  (CSI = 0.32)   ➜  OK
LL Allowable: L/720
TL Allowable: L/480
9/22/2023 5
ΔLL = = 0.41 in.
(L/d)LL = 223.00 / 0.41 = 539
 ΔLL = 0.41 in = L/539 > L/720   ➜  NG
ΔTL = = 0.75 in.
(L/d)TL = 223.00 / 0.75 = 296
 ΔTL = 0.75 in = L/296 > L/480   ➜  NG
Ab = b x lb = 5.5 x 5 = 27.50 in2
fc⊥ = = 138.3 psi
 fc⊥ = 138.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.21)   ➜  OK
9/22/2023 6
