Size: 5.5 x 15
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Selfweight: 275.6 lbs
Dist. Selfweight: 19.34 plf
Total Weight: 280.5 lbs
Beam Design Adam Goldfine 38212 n 25th ave phoenix az 85086 rev1
9/20/2023 1
d = 15.000 in.
A = 5.500 x 15.000 = 82.50 in.2
Sx = (5.500)(15.000)2/6 = 206.25 in.3
Sy = (5.500)2(15.000)/6 = 75.63 in.3
Ix = (5.500)(15.000)3/12 = 1546.88 in.4
Iy = (5.500)3(15.000)/12 = 207.97 in.4
9/20/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [82.50 x (171.00 + 3)] x (12 in./ft.)3 = 8.31 ft3
Volumespan = N[A x L] = 1 x [82.50 x 171.00] x (12 in./ft.)3 = 8.16 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.31 = 280.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.16 = 275.6 lbs
Distributed Self Weight (ws) = = 19.34 plf
  ws = 19.34 plf
14.25 ft.
14.50 ft.
1408.98 lbs
1408.98 lbs
9/20/2023 3
fb = = 287.0 psi
 fb = 287.0 psi < Fbx' = 2760.0 psi  (CSI = 0.10)   ➜  OK
9/20/2023 4
fv* = = 20.76 psi
 fv* = 20.76 psi < Fvx' = 304.75 psi  (CSI = 0.07)   ➜  OK
fv = = 25.18 psi
 fv = 25.18 psi < Fvx' = 304.75 psi  (CSI = 0.08)   ➜  OK
9/20/2023 5
ΔLL = = 0.03 in.
(L/d)LL = 171.00 / 0.03 = 5132
 ΔLL = 0.03 in = L/5132 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 171.00 / 0.06 = 2641
 ΔTL = 0.06 in = L/2641 < L/240   ➜  OK
fc⊥ = = 85.4 psi
 fc⊥ = 85.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.13)   ➜  OK
9/20/2023 6
