Beam Design - Ridge Beam
Size: 3.5 x 15
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 570 plf
Dead Load: 285 plf
Selfweight: 175.4 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 178.5 lbs
Beam Design Clayton Crites 202 Old Moscow Highway Scourey
9/19/2023 1
d = 15.000 in.
9/19/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (171.00 + 3)] x (12 in./ft.)3 = 5.29 ft3
Volumespan = N[A x L] = 1 x [52.50 x 171.00] x (12 in./ft.)3 = 5.20 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.29 = 178.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.20 = 175.4 lbs
570 plf
285 plf
  ws = 12.31 plf
14.25 ft.
14.50 ft.
6287.99 lbs
6287.99 lbs
9/19/2023 3
fb = = 2012.8 psi
 fb = 2012.8 psi < Fbx' = 2760.0 psi  (CSI = 0.73)   ➜  OK
9/19/2023 4
fv* = = 145.58 psi
 fv* = 145.58 psi < Fvx' = 304.75 psi  (CSI = 0.48)   ➜  OK
fv = = 176.56 psi
 fv = 176.56 psi < Fvx' = 304.75 psi  (CSI = 0.58)   ➜  OK
9/19/2023 5
ΔLL = = 0.30 in.
(L/d)LL = 171.00 / 0.30 = 573
 ΔLL = 0.30 in = L/573 < L/360   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 171.00 / 0.45 = 377
 ΔTL = 0.45 in = L/377 < L/240   ➜  OK
fc⊥ = = 598.9 psi
 fc⊥ = 598.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.92)   ➜  OK
9/19/2023 6
