Beam Design - Front Loaded beam
Size: 5.5 x 24
Design Span (L): 38.25 ft.
Clear Span: 38.00 ft.
Total Span: 38.50 ft.
Live Load: 4560 lbs
Dead Load: 2280 lbs
Selfweight: 1183.8 lbs
Dist. Selfweight: 30.95 plf
Total Weight: 1191.5 lbs
CV Volume Factor 0.873b - - - - -
Beam Design Clayton Crites 202 Old Moscow Highway Scourey
9/19/2023 1
d = 24.000 in.
A = 5.500 x 24.000 = 132.00 in.2
Sx = (5.500)(24.000)2/6 = 528.00 in.3
Sy = (5.500)2(24.000)/6 = 121.00 in.3
Ix = (5.500)(24.000)3/12 = 6336.00 in.4
Iy = (5.500)3(24.000)/12 = 332.75 in.4
9/19/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [132.00 x (459.00 + 3)] x (12 in./ft.)3 = 35.29 ft3
Volumespan = N[A x L] = 1 x [132.00 x 459.00] x (12 in./ft.)3 = 35.06 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 35.29 = 1191.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 35.06 = 1183.8 lbs
Distributed Self Weight (ws) = = 30.95 plf
4560 lbs
2280 lbs
  ws = 30.95 plf
38.25 ft.
38.00 ft.
38.50 ft.
4015.74 lbs
4015.74 lbs
9/19/2023 3
CV = = 0.873
CV = 0.873 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.873) = 2408.2 psi
fb = = 1615.2 psi
 fb = 1615.2 psi < Fbx' = 2408.2 psi  (CSI = 0.67)   ➜  OK
9/19/2023 4
fv* = = 44.89 psi
 fv* = 44.89 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
fv = = 45.59 psi
 fv = 45.59 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
9/19/2023 5
ΔLL =   =   = 0.81 in.
(L/d)LL = 459.00 / 0.81 = 570
 ΔLL = 0.81 in = L/570 < L/360   ➜  OK
ΔTL =   =   = 1.34 in.
(L/d)TL = 459.00 / 1.34 = 343
 ΔTL = 1.34 in = L/343 < L/240   ➜  OK
fc⊥ = = 243.4 psi
 fc⊥ = 243.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.37)   ➜  OK
9/19/2023 6
