Beam Design - Side loaded beams
Size: 3.5 x 12
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 315 plf
Dead Load: 157.5 plf
Selfweight: 140.3 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 142.8 lbs
Beam Design Clayton Crites 202 Old Moscow Highway Scourey
9/19/2023 1
9/19/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (171.00 + 3)] x (12 in./ft.)3 = 4.23 ft3
Volumespan = N[A x L] = 1 x [42.00 x 171.00] x (12 in./ft.)3 = 4.16 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.23 = 142.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.16 = 140.3 lbs
315 plf
157.5 plf
  ws = 9.85 plf
14.25 ft.
14.50 ft.
3497.02 lbs
3497.02 lbs
9/19/2023 3
fb = = 1749.0 psi
 fb = 1749.0 psi < Fbx' = 2760.0 psi  (CSI = 0.63)   ➜  OK
9/19/2023 4
fv* = = 105.51 psi
 fv* = 105.51 psi < Fvx' = 304.75 psi  (CSI = 0.35)   ➜  OK
fv = = 122.74 psi
 fv = 122.74 psi < Fvx' = 304.75 psi  (CSI = 0.40)   ➜  OK
9/19/2023 5
ΔLL = = 0.32 in.
(L/d)LL = 171.00 / 0.32 = 531
 ΔLL = 0.32 in = L/531 < L/360   ➜  OK
ΔTL = = 0.49 in.
(L/d)TL = 171.00 / 0.49 = 347
 ΔTL = 0.49 in = L/347 < L/240   ➜  OK
fc⊥ = = 333.0 psi
 fc⊥ = 333.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.51)   ➜  OK
9/19/2023 6
