Beam Design - 31 Grand Beach
Size: 5.5 x 19.5
Design Span (L): 29.75 ft.
Clear Span: 29.50 ft.
Total Span: 30.00 ft.
Live Load: 600 plf
Dead Load: 200 plf
Selfweight: 748.1 lbs
Dist. Selfweight: 25.15 plf
Total Weight: 754.4 lbs
Load Duration: 1.60
Notes: Beams at offset north walls
CL Beam Stability Factor 0.974 - - - - -
CV Volume Factor 0.914b - - - - -
Beam Design Randall
9/15/2023 1
d = 19.500 in.
A = 5.500 x 19.500 = 107.25 in.2
Sx = (5.500)(19.500)2/6 = 348.56 in.3
Sy = (5.500)2(19.500)/6 = 98.31 in.3
Ix = (5.500)(19.500)3/12 = 3398.48 in.4
Iy = (5.500)3(19.500)/12 = 270.36 in.4
Beam Design Randall
9/15/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [107.25 x (357.00 + 3)] x (12 in./ft.)3 = 22.34 ft3
Volumespan = N[A x L] = 1 x [107.25 x 357.00] x (12 in./ft.)3 = 22.16 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 22.34 = 754.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 22.16 = 748.1 lbs
Distributed Self Weight (ws) = = 25.15 plf
600 plf
200 plf
  ws = 25.15 plf
29.75 ft.
29.50 ft.
30.00 ft.
12377.18 lbs
12377.18 lbs
Beam Design Randall
9/15/2023 3
lu = Unbraced Length = 6 ft.
lu/d = = 3.69
le = 2.06lu = 2.06(72.0) = 148.32 in. = 12.36 ft.  (NDS Table 3.3.3)
Rb = = 9.78
 Rb = 9.78 < 50   ➜  OK
Beam Design Randall
9/15/2023 4
FbE = = 10668.20 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.60)(1)(1) = 3840.00 psi
CL =   = 0.974
CV = = 0.914
CV = 0.914 < CL = 0.974
Fbx' = (2400)(1.60)(1)(1)(0.914) = 3507.9 psi
fb = = 3142.8 psi
 fb = 3142.8 psi < Fbx' = 3507.9 psi  (CSI = 0.90)   ➜  OK
Fvx' = (265)(1.60)(1)(1) = 424.00 psi
fv* = = 152.91 psi
Beam Design Randall
9/15/2023 5
 fv* = 152.91 psi < Fvx' = 424.00 psi  (CSI = 0.36)   ➜  OK
fv = = 171.66 psi
 fv = 171.66 psi < Fvx' = 424.00 psi  (CSI = 0.40)   ➜  OK
ΔLL = = 1.73 in.
(L/d)LL = 357.00 / 1.73 = 207
 ΔLL = 1.73 in = L/207 < L/180   ➜  OK
ΔTL = = 2.38 in.
(L/d)TL = 357.00 / 2.38 = 150
 ΔTL = 2.38 in = L/150 < L/120   ➜  OK
Beam Design Randall
9/15/2023 6
fc⊥ = = 750.1 psi
 fc⊥ = 750.1 psi > Fc⊥x' = 650.00 psi  (CSI = 1.15)   ➜  NG
Beam Design Randall
9/15/2023 7
