Size: 6.75 x 24
Design Span (L): 19.50 ft.
Clear Span: 19.00 ft.
Total Span: 20.00 ft.
Live Load: 330 plf
Dead Load: 165 plf
Selfweight: 740.6 lbs
Dist. Selfweight: 37.98 plf
Total Weight: 759.6 lbs
Defl. Limits: 900|600
CV Volume Factor 0.914b - - - - -
Beam Design 21 sahhali
9/14/2023 1
b = 6.750 in.
d = 24.000 in.
A = 6.750 x 24.000 = 162.00 in.2
Sx = (6.750)(24.000)2/6 = 648.00 in.3
Sy = (6.750)2(24.000)/6 = 182.25 in.3
Ix = (6.750)(24.000)3/12 = 7776.00 in.4
Iy = (6.750)3(24.000)/12 = 615.09 in.4
9/14/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [162.00 x (234.00 + 6)] x (12 in./ft.)3 = 22.50 ft3
Volumespan = N[A x L] = 1 x [162.00 x 234.00] x (12 in./ft.)3 = 21.94 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 22.50 = 759.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 21.94 = 740.6 lbs
Distributed Self Weight (ws) = = 37.98 plf
330 plf
165 plf
  ws = 37.98 plf
19.50 ft.
19.00 ft.
5329.81 lbs
5329.81 lbs
9/14/2023 3
CV = = 0.914
CV = 0.914 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.914) = 2194.7 psi
fb = = 469.1 psi
 fb = 469.1 psi < Fbx' = 2194.7 psi  (CSI = 0.21)   ➜  OK
9/14/2023 4
fv* = = 38.25 psi
 fv* = 38.25 psi < Fvx' = 265.00 psi  (CSI = 0.14)   ➜  OK
fv = = 48.12 psi
 fv = 48.12 psi < Fvx' = 265.00 psi  (CSI = 0.18)   ➜  OK
LL Allowable: L/900
TL Allowable: L/600
9/14/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 234.00 / 0.08 = 3051
 ΔLL = 0.08 in = L/3051 < L/900   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 234.00 / 0.12 = 1889
 ΔTL = 0.12 in = L/1889 < L/600   ➜  OK
fc⊥ = = 131.6 psi
 fc⊥ = 131.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.20)   ➜  OK
9/14/2023 6
