Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 368 plf
Dead Load: 142 plf
Selfweight: 117.2 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 120.2 lbs
Beam Design 2023A353
9/14/2023 1
9/14/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (117.00 + 3)] x (12 in./ft.)3 = 3.52 ft3
Volumespan = N[A x L] = 3 x [16.88 x 117.00] x (12 in./ft.)3 = 3.43 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.52 = 120.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.43 = 117.2 lbs
368 plf
142 plf
ws = 12.02 plf
9.75 ft.
9.50 ft.
10.00 ft.
2610.12 lbs
2610.12 lbs
9/14/2023 3
fb = = 784.2 psi
 fb = 784.2 psi < Fbx' = 1035.0 psi  (CSI = 0.76)   ➜  OK
9/14/2023 4
fv* = = 60.90 psi
 fv* = 60.90 psi < Fvx' = 207.00 psi  (CSI = 0.29)   ➜  OK
fv = = 75.40 psi
 fv = 75.40 psi < Fvx' = 207.00 psi  (CSI = 0.36)   ➜  OK
9/14/2023 5
ΔLL = = 0.09 in.
(L/d)LL = 117.00 / 0.09 = 1336
 ΔLL = 0.09 in = L/1336 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 117.00 / 0.12 = 942
 ΔTL = 0.12 in = L/942 < L/240   ➜  OK
fc⊥ = = 193.3 psi
 fc⊥ = 193.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
9/14/2023 6
