Grade: 24F-V5 1.7E DF/HF
Size: 5.125 x 22.5
Selfweight: 317.7 lbs
Dist. Selfweight: 27.04 plf
Total Weight: 324.4 lbs
Orientation: Horizontal
Cfu Flat Use Factor 1.099c - - - - -
Beam Design 2023A352
9/13/2023 1
b = 5.125 in.
d = 22.500 in.
A = 5.125 x 22.500 = 115.31 in.2
Sx = (5.125)(22.500)2/6 = 432.42 in.3
Sy = (5.125)2(22.500)/6 = 98.50 in.3
Ix = (5.125)(22.500)3/12 = 4864.75 in.4
Iy = (5.125)3(22.500)/12 = 252.40 in.4
24F-V5 1.7E DF/HF 2400 1600 650 215 1700000 900000 1350 375 200 1500000 790000 1100 1450 0.5
9/13/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [115.31 x (141.00 + 3)] x (12 in./ft.)3 = 9.61 ft3
Volumespan = N[A x L] = 1 x [115.31 x 141.00] x (12 in./ft.)3 = 9.41 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.61 = 324.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.41 = 317.7 lbs
Distributed Self Weight (ws) = = 27.04 plf
  ws = 27.04 plf
1212.21 lbs
1212.21 lbs
9/13/2023 3
Cfu = = 1.099
Fby' = (1350)(1.00)(1)(1)(1)(1.099) = 1483.8 psi
fb = = 424.8 psi
 fb = 424.8 psi < Fby' = 1483.8 psi  (CSI = 0.29)   ➜  OK
9/13/2023 4
Fvy' = (200)(1.00)(1)(1) = 215.00 psi
fv* = = 14.32 psi
 fv* = 14.32 psi < Fvy' = 200.00 psi  (CSI = 0.07)   ➜  OK
fv = = 15.44 psi
 fv = 15.44 psi < Fvy' = 200.00 psi  (CSI = 0.08)   ➜  OK
Ey' = Ey(CM)(Ct) = 1500000(1)(1) = 1500000 psi
9/13/2023 5
ΔLL = = 0.11 in.
(L/d)LL = 141.00 / 0.11 = 1245
 ΔLL = 0.11 in = L/1245 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 141.00 / 0.23 = 616
 ΔTL = 0.23 in = L/616 < L/240   ➜  OK
Fc⊥y' = (375)(1)(1) = 375.00 psi
Ab = d x lb = 22.5 x 3 = 67.50 in2
fc⊥ = = 18.0 psi
 fc⊥ = 18.0 psi < Fc⊥y' = 375.00 psi  (CSI = 0.05)   ➜  OK
9/13/2023 6
