Grade: SPF SS
Design Span (L): 8.71 ft.
Clear Span: 8.42 ft.
Total Span: 9.00 ft.
Bearing (lb): 3.5 in.
Live Load: . lbs
Dead Load: 1300 lbs
Selfweight: 43.6 lbs
Dist. Selfweight: 5.00 plf
Total Weight: 45.0 lbs
Beam Design 2023A347
9/9/2023 1
9/9/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (104.50 + 3.5)] x (12 in./ft.)3 = 1.55 ft3
Volumespan = N[A x L] = 3 x [8.25 x 104.50] x (12 in./ft.)3 = 1.50 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.55 = 45.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.50 = 43.6 lbs
Distributed Self Weight (ws) = = 5.00 plf
. lbs
1300 lbs
ws = 5.00 plf
8.71 ft.
8.42 ft.
9.00 ft.
672.50 lbs
672.50 lbs
9/9/2023 3
Fbx' = (1250)(1.00)(1)(1)(1)(1.3)(1)(1) = 1625.0 psi
fb = = 1522.0 psi
 fb = 1522.0 psi < Fbx' = 1625.0 psi  (CSI = 0.94)   ➜  OK
9/9/2023 4
fv* = = 40.57 psi
 fv* = 40.57 psi < Fvx' = 135.00 psi  (CSI = 0.30)   ➜  OK
fv = = 40.71 psi
 fv = 40.71 psi < Fvx' = 135.00 psi  (CSI = 0.30)   ➜  OK
9/9/2023 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 104.50 / 0.00 = ∞
ΔTL =   =   = 0.34 in.
(L/d)TL = 104.50 / 0.34 = 310
 ΔTL = 0.34 in = L/310 < L/120   ➜  OK
fc⊥ = = 42.7 psi
 fc⊥ = 42.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.10)   ➜  OK
9/9/2023 6
