Grade: SP DSS
Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 650 plf
Dead Load: 130 plf
Selfweight: 41.6 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 43.7 lbs
Load Duration: 1.60
Beam Design 2023A341
8/31/2023 1
8/31/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (57.00 + 3)] x (12 in./ft.)3 = 1.17 ft3
Volumespan = N[A x L] = 2 x [16.88 x 57.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.17 = 43.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.11 = 41.6 lbs
650 plf
130 plf
ws = 8.75 plf
4.75 ft.
4.50 ft.
5.00 ft.
1971.87 lbs
1971.87 lbs
8/31/2023 3
Fbx' = (1800)(1.60)(1)(1)(1)(1)(1)(1) = 2880.0 psi
fb = = 421.8 psi
 fb = 421.8 psi < Fbx' = 2880.0 psi  (CSI = 0.15)   ➜  OK
8/31/2023 4
Fvx' = (175)(1.60)(1)(1)(1) = 280.00 psi
fv* = = 50.39 psi
 fv* = 50.39 psi < Fvx' = 280.00 psi  (CSI = 0.18)   ➜  OK
fv = = 83.26 psi
 fv = 83.26 psi < Fvx' = 280.00 psi  (CSI = 0.30)   ➜  OK
8/31/2023 5
ΔLL = = 0.01 in.
(L/d)LL = 57.00 / 0.01 = 5178
 ΔLL = 0.01 in = L/5178 < L/240   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 57.00 / 0.01 = 4267
 ΔTL = 0.01 in = L/4267 < L/180   ➜  OK
fc⊥ = = 219.1 psi
 fc⊥ = 219.1 psi < Fc⊥x' = 660.00 psi  (CSI = 0.33)   ➜  OK
8/31/2023 6
