Design Span (L): 8.00 ft.
Clear Span: 7.71 ft.
Total Span: 8.29 ft.
Bearing (lb): 3.5 in.
Selfweight: 31.4 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 32.5 lbs
Beam Design 2023A34
2/20/2023 1
Beam Design 2023A34
2/20/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (96.00 + 3.5)] x (12 in./ft.)3 = 0.95 ft3
Volumespan = N[A x L] = 2 x [8.25 x 96.00] x (12 in./ft.)3 = 0.92 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.95 = 32.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.92 = 31.4 lbs
ws = 3.92 plf
7.71 ft.
8.29 ft.
741.77 lbs
741.77 lbs
Beam Design 2023A34
2/20/2023 3
fb = = 1135.6 psi
 fb = 1135.6 psi < Fbx' = 1170.0 psi  (CSI = 0.97)   ➜  OK
Beam Design 2023A34
2/20/2023 4
fv* = = 57.61 psi
 fv* = 57.61 psi < Fvx' = 180.00 psi  (CSI = 0.32)   ➜  OK
fv = = 65.06 psi
 fv = 65.06 psi < Fvx' = 180.00 psi  (CSI = 0.36)   ➜  OK
Beam Design 2023A34
2/20/2023 5
ΔLL = = 0.14 in.
(L/d)LL = 96.00 / 0.14 = 693
 ΔLL = 0.14 in = L/693 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 96.00 / 0.25 = 387
 ΔTL = 0.25 in = L/387 < L/240   ➜  OK
fc⊥ = = 70.6 psi
 fc⊥ = 70.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
Beam Design 2023A34
2/20/2023 6
