Beam Design - Deck Extension
Grade: SP DSS
Design Span (L): 11.85 ft.
Clear Span: 11.60 ft.
Total Span: 12.10 ft.
Live Load: 153 plf
Selfweight: 88.1 lbs
Dist. Selfweight: 7.44 plf
Total Weight: 90.0 lbs
CL Beam Stability Factor 0.977 - - - - -
Beam Design Gary Van Balen 106 Redmond Ct n/a
8/30/2023 1
8/30/2023 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (142.20 + 3)] x (12 in./ft.)3 = 2.33 ft3
Volumespan = N[A x L] = 2 x [13.88 x 142.20] x (12 in./ft.)3 = 2.28 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.33 = 90.0 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.28 = 88.1 lbs
Distributed Self Weight (ws) = = 7.44 plf
153 plf
ws = 7.44 plf
11.85 ft.
11.60 ft.
12.10 ft.
1424.38 lbs
1424.38 lbs
8/30/2023 3
lu = Unbraced Length = 6 ft.
lu/d = = 7.78
le = 1.63lu + 3d = 1.63(72.0) + 3(9.25) = 145.11 in. = 12.09 ft.  (NDS Table 3.3.3)
Rb = = 12.21
 Rb = 12.21 < 50   ➜  OK
8/30/2023 4
Eminy' = Eminy(CM)(Ct)(Ci) = 690000(0.9)(1)(1) = 621000 psi
FbE = = 4996.62 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1950)(1.00)(0.85)(1)(1)(1)(1) = 1657.50 psi
CL =   = 0.977
Fbx' = (1950)(1.00)(0.85)(1)(0.977)(1)(1)(1) = 1618.7 psi
fb = = 1159.2 psi
 fb = 1159.2 psi < Fbx' = 1618.7 psi  (CSI = 0.72)   ➜  OK
fv* = = 65.59 psi
 fv* = 65.59 psi < Fvx' = 169.75 psi  (CSI = 0.39)   ➜  OK
fv = = 75.40 psi
 fv = 75.40 psi < Fvx' = 169.75 psi  (CSI = 0.44)   ➜  OK
8/30/2023 5
ΔLL = = 0.20 in.
(L/d)LL = 142.20 / 0.20 = 709
 ΔLL = 0.20 in = L/709 < L/360   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 142.20 / 0.31 = 461
 ΔTL = 0.31 in = L/461 < L/240   ➜  OK
Fc⊥x' = (660)(0.67)(1)(1) = 442.20 psi
fc⊥ = = 158.3 psi
 fc⊥ = 158.3 psi < Fc⊥x' = 442.20 psi  (CSI = 0.36)   ➜  OK
8/30/2023 6
