Beam Design - Decking
Design Span (L): 1.92 ft.
Clear Span: 1.67 ft.
Total Span: 2.17 ft.
Live Load: 300 lbs
Dead Load: 200 lbs
Selfweight: 4.1 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 4.6 lbs
Orientation: Horizontal
Beam Design Luis Lopez Savinon 2023A336
8/24/2023 1
8/24/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (23.00 + 3)] x (12 in./ft.)3 = 0.12 ft3
Volumespan = N[A x L] = 1 x [8.25 x 23.00] x (12 in./ft.)3 = 0.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.12 = 4.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.11 = 4.1 lbs
Distributed Self Weight (ws) = = 2.14 plf
300 lbs
200 lbs
ws = 2.14 plf
1.92 ft.
1.67 ft.
2.17 ft.
252.32 lbs
252.32 lbs
8/24/2023 3
Fby' = (1000)(1.15)(1)(1)(1)(1)(1.15)(1)(1) = 1322.5 psi
fb = = 1399.9 psi
 fb = 1399.9 psi > Fby' = 1322.5 psi  (CSI = 1.06)   ➜  NG
8/24/2023 4
Fvy' = (175)(1.15)(1)(1)(1) = 201.25 psi
fv* = = 45.78 psi
 fv* = 45.78 psi < Fvy' = 201.25 psi  (CSI = 0.23)   ➜  OK
fv = = 45.83 psi
 fv = 45.83 psi < Fvy' = 201.25 psi  (CSI = 0.23)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(1) = 1400000 psi
8/24/2023 5
ΔLL =   =   = 0.04 in.
(L/d)LL = 23.00 / 0.04 = 655
 ΔLL = 0.04 in = L/655 < L/180   ➜  OK
ΔTL =   =   = 0.06 in.
(L/d)TL = 23.00 / 0.06 = 391
 ΔTL = 0.06 in = L/391 < L/120   ➜  OK
Fc⊥y' = (565)(1)(1)(1) = 565.00 psi
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 15.3 psi
 fc⊥ = 15.3 psi < Fc⊥y' = 565.00 psi  (CSI = 0.03)   ➜  OK
8/24/2023 6
